fj12ryder
Jun 09, 2014Explorer III
If Pin Weight is the amount of weight loaded onto the hitch then how do you find out what the hitch weighs with the load on it? You weigh the truck on has the hitch mounted in it. What NC Hauler is saying is Rear Axle weight gain is Total Hitch weight, not the total amount the truck/hitch gains when the 5th wheel is loaded. Which is incorrect IMO.
Another way to look at it: If you mounted the hitch on a tripod, put the tripod on a scale, and then put the 5th wheel on that hitch, what would the weight be? In this case the weight would be 2440 lbs.
About Fifth Wheel Group
