avvidclif1
Jun 09, 2014Explorer
On Pin Weight; I can see adding whatever was applied to the front axle to the pin weight, That's the weight applied to the TV by the trailer. BUT You can't subtract any change in the front axle weight from the pin weight. The weight is there just behind the rear axle unloading the front.
There are 2 numbers I am concerned with. The actual weight on my rear tires(axle) to not exceed the RAWR. And the GVWR(weight on TV when hitched up, front plus rear)
About Fifth Wheel Group
