NC_Hauler
Jun 09, 2014Explorer
fj12ryder wrote:NC Hauler wrote:Okay, I promise no more disagreement :) ..but suppose you didn't have access to a scale with the ability to weigh front and rear axles separately. You could only weigh both at the same time. No way to weigh them separately, no way. Now you want to find your Pin Weight, which we both agree is the weight added to the truck when you put the 5th wheel on the hitch. The only way to now do that is to take unloaded weight and subtract it from the loaded weight. Which in the case of the OP will amount to 2440 lbs: Unloaded weight of 8460 lbs. from the loaded weight of 10900 lbs.fj12ryder wrote:
Your argument makes sense if the weight added to the hitch only affects the Rear Axle.
To me Pin Weight is the amount of weight added to my truck when the 5th wheel is attached, or the amount of weight on the pin/5th wheel hitch. This weight is ascertained by weighing the truck unloaded and loaded, and then subtracting the unloaded weight from the loaded weight.
That, to me, is Pin Weight. We'll have to agree to disagree on it. :)
You just stated EXACTLY what I've been saying all along!!..where did you not understand what I stated...I even gave the definition, which you just repeated almost verbatim.....I don't understand where I lost you....
One more time...'Pin weight is defined as the weight put on the 5th wheel hitch when you hook to the 5er.... I weigh my truck with no 5er hooked up...I see the weight that is printed out for drive axle with no 5er hooked up, ie, the rear axle... then I load the 5er and subtract the difference,... that gives me "pin weight"..you are agreeing with me......
my rear axle weight with truck completed loaded, ready to camp LESS 5er hooked to the hitch weighed 3860#..THEN all I did was hook my 5er up to my hitch, rear axle weight increased from 3860# to 7200#...(my hitch is almost directly over my rear axle, in the bed of the truck)...I take 7200# (weight with 5er king pin setting on my hitch and subtract it from weight of rear axle without 5er king pin setting on the hitch, 7200 less 3860# and get my pin weight of 3340#.
Your words, "This weight is ascertained by weighing the truck unloaded and loaded, and then subtracting the unloaded weight from the loaded weight. "
That is exactly what I said..re-read my post...re-read the definition of what "pin weight" is. You said EXACTLY the same thing I've been saying all along..
oh...thanks for agreeing with me, we're saying the exact same thing...:)
Okay, that's my last word on the subject. :) Except I think that he does need to level out his weight on the trailer axles. Seems to me a 1000 lbs. difference is pretty substantial. JMO of course.
I agree with you as I too recommend he try to level out his 5er.
Most don't really concern themselves with pin weight...to some it's a pain to do all we've been talking about doing...A lot just don't care from all I've gathered over the years. Most CAT scales I've ever seen weigh exactly the way I stated doing the weights. those towing don't want to disconnect, weigh, reconnect and weigh again. I'm fortunate to have a truck stop with CAT scale very close to my home. I loaded up my truck ready to camp and weighed it, a week later, I had the truck pretty much exactly the way it was when I first weighed it...THIS TIME, I had the 5er hooked to it, so I have two cat scale sheets with and without 5er hooked up. That's how I got all my weights...In fact, 5er weighed in at 15,920#..if I add that extra 180# that went to my front axle, it would make 5er's GW as 16,100# (GVW is almost 17,000#). BUT, that is a whole different issue.
and again, I'm just going by the definition of "pin weight", how it is defined and how to obtain it .....so the answer to your last question is, he'll end up with a "ballpark", idea of what his pin weight "might be", but it won't be done correctly or accurately until he can do the weigh checks per the formula on how to determine "pin weight", per the definition of pin weight....:)
About Fifth Wheel Group
