Lwiddis
Jun 26, 2021Navigator
“Should we try and squeeze into something smaller than 39' or splurge on a larger 45'? or something in between?”
The longer you go the fewer the campgrounds you can use. Most private RV parks will accommodate you. Many USFS CGs and National and state parks will not even at 39 feet. If you scout ahead when boondocking you will be OK.
Buy or select the 5er first. Then match a TV to it. I would not consider any RV without at least one slide.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
