4x4ord
Jun 26, 2021Explorer III
Whether you buy Ram Ford or GM is strictly a matter of personal choice. You will want a dually. Mobile Suite, as suggested by Cummins, is probably the 5th wheel manufacturer I’d recommend as well. If you buy a Ford I would choose 2020 or newer and an F350 with 3.55 gears over a F450. The 450 has a tighter turning radius which would be nice but I would find the 4.30 rear end much less desirable than 3.55 gears which can be selected on an f350. The 450 is geared for much heavier work than towing an RV. 100k is more than what is needed to purchase a new F350 Platinum with the Diesel engine. Everyone has their own idea as to what hitch to get. B&W makes a hitch that most are 100% satisfied with …. It’s a little heavy to put in and out.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
