bertschb
Nov 15, 2015Explorer
Help with hitch decision
I just ordered a new Grand Design Reflection 318RST 5th wheel (GVWR 13,995) and plan to buy a 2016 GMC 3500 Duramax truck next. The truck has a 6.5' bed.
I've spent a week reading up on hitches on multiple forums and I've narrowed my choice of hitches to the B&W Companion and Trailer Saver BD3 Air-Ride.
My needs:
I want the hitch to be completely removed from the bed when not in use (nothing at all showing).
It has to be something I can lift out myself without a hoist.
It needs to provide a smooth ride that protects the truck and 5th wheel.
Is there a factory under bed hitch mount option I should order with my truck that will make installing the hitch easier or can I get everything I need from the hitch manufacturers? I guess I'll throw in one more question while I'm at it...Can I get the best of both worlds by replacing the pin box on the 5th wheel with a Trail-Air and then getting the B&W Companion which appears to be lighter for removing from the bed?
Kind of overwhelmed with all the options available. Money is no object which helps. Any help would be appreciated!
My needs:
