RollandB
Nov 18, 2015Explorer
You may need to contact a professional to have the cleaning of the black tank dealt with if it escaped the toilet bowl. The same company can probably deal with getting things dried out. A combination of air movement, heat, and dehumidifying plus removing insulation as you noted will get things dried out. With all that equipment it will sound like an airport in your RV and should be very warm. Good luck!
About Fifth Wheel Group
19,031 PostsLatest Activity: Dec 16, 2025
