22WANDER
Feb 24, 2014Explorer
Water Water Everywhere
Setup RV at campground and went out for a while and when we returned water was running out from under the RV. The valve was in the coach use position not in the tank fill position and the fresh water tank was full. My question is do these plastic valves fail or leak ? Also when the water is turned off at the campground tap and we try to use the in house water pump it runs all the time. I had spare pump and changed out the pump. Same the thing happens the pump runs all the time. So I am thinking its the valve (city fill/tank fill). Are the two connected ? So the only way to get water in the coach is to turn on the pump that runs nonstop. I don't want to burn up the pump.
