wedge542 wrote:
mr taylor, you are correct id be way better off but current situation has me bound with what i have at hand now, not to say im gonna do this regaurdless because if i cant do it legaly im not leaving the house, its not worth it, i bought a slider 5th wheel this evening and it moves the pin foward about 6 inches, i hooked up and made sure turns no problems and i can still leave tailgate open when hooking up, i loaded up a truck and going to the scales in the morning to see whats what on the steer/drives/total and ill post numbers here, already know what my combo weighs empty so then ill know how much this truck weighs i loaded on the trailer, its a dualy loaded with stuff. IF this will not work ill contact ford because the f250 and 350 are same axels brakes springs housings bearings ect. thank you mr taylor
No problem glad I could help. Good luck to ya and I hope everything turns out your way !!
