wedge542's avatar
wedge542
help with weight
I got all the numbers but cant figure it all out to get legal, i dont care what its capable of just need to be legal going across scales, this is not a rv but is a gooseneck type 5th wheel flatbed weighs 5600lbs on cat scales truck was 7260 half tank tool box me hooked together 12900 total steer was 4020 drive was 4320 trailer axel was 4560. Trailer is a tri axel with 6000 axels. This is a 2005 f250 crew cab 4x2 6.0 auto single wheel drv with 3150lb tires. Ford shows a 9600lb door sticker gvwr-4850 front/6100 rear and a 23000lb gcwr and a 17000lb max 5th wheel weight, Im trying to figure how much cargo i can legaly put on the trailer that will not over the pin and how much the scales should show when loaded legal, ill be crossing dot scales every state, prob pulled over alot to get scaled. Iknow everybody has there way of figuring but im looking for actual legal dot/fmcsa limits, please keep it simple in laymens terms, i just need to know what i can put on trailer and pin area. thank you
  • LOL...your going to get all kinds of answers from a RV website that few if any has never made a living pulling GN trailers and crossing DOT scales multi state.
    NOTE
    " Unless your F250 truck and trailer is registered commercially dot doesn't want you on the scales or even taking up space in the entrance line."
    If your registered commercially your trucks 9600 GVWR and the trailers 17000 GVWR = 26660 lbs for your declared GCW operating max. Now if your state allows you to register your F250 at 10950 (sum of the axle ratings) then you can declare a 27950 GCW as your max operating range You can't exceed the trucks drive or steer axle/tire rating or the trailers axle/tire ratings.
    DOT can take the lessor of a axle or tire rating. I've had them crawl under my trailers to find the axle tag.
    Be sure and have your med card filed and up to date along your IFTA sticker. If your a commercial operator then you will know all the rest of your requirements.
    If your a new entrant in the commercial hauling world then there are several websites dedicated just for those folks looking for info. Those type forum members can separate internet myth vs how its actually done.
    Let google be your friend.
  • I think you've got all the numbers you need, except for the pin weight.
    You know you can't go over 17k on the trailer, or 23k combined. Can't be over 6,100 on rear axle, etc. In your case, GCVWR will be around 15,700, because 23,000 - 7,260 = 15,740. Seems your trailer can handle that okay. But your truck cannot.
    You've got 2,340 of remaining GVWR capacity. You've got only 1,780 of remaining rear axle weight capacity. Because 15% of 15,740 is 2,360. Too much for your rear axle if you must follow the ratings.
    Since it is a flatbed, your pin weight can vary widely based upon how you load the trailer. It could even be zero, or a negative number on the pin if you loaded badly behind the axles. Don't do that, it won't tow well. Shoot for 15% of total load on the pin as a minimum for safe handling. Plan to cross a scale before you get out of town, and be prepared to shift the load if the numbers don't work.
    I think you're looking at a max trailer weight of about 12k if you can load so that 15% is on the pin (1,800). 12k minus your trailer tare weight of 5,600 is a net cargo weight of 6,400. Might be asking a lot to load that perfectly, so reality might be a bit lower than that.
