Texas_Flash's avatar
Texas_Flash
Hitch Question
I have a Curt Q20 hitch that is on the tallest setting. My new trailer is riding nose down on the hitch. The pinbox is a Trailair Rotoflex also on the highest setting. With the current set-up is there anything available to raise the hitch?
  • It is a bit like differential gear ratios. Higher is lower and lower is higher.
    Chris
  • Cummins12V98 wrote:
    Hiking Hunter wrote:
    If your trailer is nose down and your Trailair is at the "highest" setting, can you just move the Trailair down? That would raise the trailer nose.
    Am I understanding your current settings correctly?
    Wondering the same!
    12V98 is thinking as I would down for up and up for down.
    chevman
    Wondering the same!
  • I have your same system, thus I cannot understand what is going on as mine is fine. A photo will be helpful to see what is going on.
  • If your trailer is nose down and your Trailair is at the "highest" setting, can you just move the Trailair down? That would raise the trailer nose.
