MFL
Jun 11, 2016Nomad II
Nevadastars wrote:
Ok, thanks Jerry. That is what I assumed, but seemed a bit weak for a heavy fiver. We are most likely going to go with a 30ft or less 1/2 ton model, so it shouldn't be an issue. I will order up rail kit from either Curt or Reese.
The custom frame mounting brackets for specific trucks are a better fit, easier to install, and maybe stronger, but I would not be concerned about the L brackets. Since you already have the universal brackets installed, and bed holes, you are right to use them.
I would not be concerned about the rails not holding, with a heavier FW. This system has been used for years, with no issues that I ever heard of.
Happy towing,
Jerry
About Fifth Wheel Group
19,020 PostsLatest Activity: Jul 19, 2025
