- 2112Explorer IILet us know if this solves your problem
- kitestiffExplorerSince I posted my question I too came across the manual for the floor slide system. I completely understand what the stop can was, but didn't know "how" it affected the slide out system. Your explanation makes sense and helps shed some light on what I need to do to try and correct the issue - THANK YOU.
2112 wrote:
Look under the slide while extended out. If your slide is like mine you will see a cylindrical 'bell' and jam nut threaded onto a shaft about 2 feet from the outside of the slide. The shaft runs through the 'bell'. This is the stop adjustment. The end of the 'bell' will come into contact with the side plate when closed.
On mine the 'bell' was too far out causing the slide to slide in farther than it should. I loosened the jam nut and rotated the bell in towards the camper to stop it sooner. Adjust it too much and the outside seal will not seal properly. I made 2 turn adjustments in until it worked properly.
I also put a witness mark on the 'bell' with a sharpie marker so I could keep track of how many turns I made.
I'll try to find time to post a photo of the adjustment 'bell'.
I hope this helps
On Edit: Look at page 11 of ***Link Removed***
The 'Bell' is called a Stop Can. Adjust the Stop Can towards the frame to stop the slide sooner. Check your outside seal to assure it's still making contact after adjusting. - 2112Explorer IILook under the slide while extended out. If your slide is like mine you will see a cylindrical 'bell' and jam nut threaded onto a shaft about 2 feet from the outside of the slide. The shaft runs through the 'bell'. This is the stop adjustment. The end of the 'bell' will come into contact with the side plate when closed.
I hope this helps
On Edit: Look at page 11 of THIS
The 'Bell' is called a Stop Can. Adjust the Stop Can towards the frame to stop the slide sooner. Check your outside seal to assure it's still making contact after adjusting. - Carlos___RanaeExplorer
kitestiff wrote:
X2 b/r slide.
My slide has this exact issue, which I solve by manually cranking a couple turns and then the motor will extend the slide (kitchen slide on 360IBL). Can you elaborate on what adjustment(s) you had to make so the slide operated correctly? Doesn't seem like a motor issue.
Thank you in advance.2112 wrote:
My KZ kitchen slide would not slide out. It made the ratchet sound, sounding like a machine gun. I could manually move it out less than an inch and then it would extend via the motor.
The dealer said it was under adjusted causing a rail to bottom out and become stuck. He shown me how to make the adjustment and no more issues.
Does yours make the ratchet sound like when it's fully closed and you continue to hold the switch?
Can you move the slide out a little with the manual tool and then it operates properly? - kitestiffExplorerMy slide has this exact issue, which I solve by manually cranking a couple turns and then the motor will extend the slide (kitchen slide on 360IBL). Can you elaborate on what adjustment(s) you had to make so the slide operated correctly? Doesn't seem like a motor issue.
Can you move the slide out a little with the manual tool and then it operates properly? - 2112Explorer IIMy KZ kitchen slide would not slide out. It made the ratchet sound, sounding like a machine gun. I could manually move it out less than an inch and then it would extend via the motor.
Can you move the slide out a little with the manual tool and then it operates properly? - TechnobodyExplorerObviously there is nothing wrong with the slide motor at all. I know I have a warning on my slide switches that say "Only operate with fully charged battery". It may be that your batteries just weren't fully charged hence it wouldn't move that slide. It may also be that it has the largest motor and draws the most amps.
I make a point of putting my slides out while still attached to the truck and the truck running. That way your batteries should be fully charged when you do disconnect.
About Fifth Wheel Group
