cummins2014
Nov 09, 2016Explorer
352 wrote:
HEREol Bombero-JC wrote:
Not sure what "kit" you mean... US Carb, or?
(I prefer Maine Diesel - send 'em your carb, returned "converted" with regulator, and necessary parts).
Converted my Yam 2400is to tri-fuel - with no intent to ever run it again on gasoline.
Works great for me - nat gas at home, propane (in needed) "on the road".
No problems *ever* with contaminated or "old" gasoline, no need for Seafoam or StaBil.
BTW - you might take your question to the Tech Forum (or ask the mod to move it) - as *everything* generator is there.
$179.00, Pretty sure I will stick to gas. One thing I did do to the Honda 2000 was I installed a shutoff valve, that ,and using a bit of gas additive, no worries about it starting or running right after prolonged sitting.
I suppose if one is using theirs a lot I could maybe see a benefit for propane, but for the occasional use, a small container of gas seems a better choice. good luck with the conversion.
About Fifth Wheel Group
