SabreCanuck
Nov 13, 2016Explorer
thomas201 wrote:
I like another poster used Honda gasoline engines converted to natural gas at work. We used casing head gas to run pump jacks in the oilfield.
They were a royal pain. Lots of failures. Problem assigned to engineer (me). Root cause, gasoline engine cooling assumes that you lose a lot of heat by evaporating the gasoline. Running at max horsepower without this additional cooling equals trashed engines.
If you do light duty they will last a long time. Running and pulling all the power they got, you will junk the engine on propane.
You need a propane engine designed from the start with propane in mind for heavy continuous duty.
Interesting results. The way I read that is you used casing head gas as the fuel?
Non-engineer minds like mine would like to know if "casing head gas" is equivalent to propane from the store? Or possibly did that gas burn hotter as well?
About Fifth Wheel Group
