- SabreCanuckExplorer
CampbellDaycruiser wrote:
IMHO propane is the most trouble/hassle to fill of all the fuels we use: for some reason I have no problem with taking a 5 gallon plastic gasoline can to be filled, but I feel like doing the same with a propane tank is being a real PITA. Stopping at a gas pump and squirting a few gallons into a can without having to go inside and find an employee to fire up the propane dispenser seems a whole lot simpler.....
Your kidding right?
Nope. My plastic gas can sits flat and does not roll around the truck like propane tanks, does not scratch what I set it on and does not have to be unstrapped and lifted out of a fitted base in a compartment that's just a bit too tall and too narrow to manage comfortably. It also weighs so much less than a propane tank when empty that my wife is even willing to carry it out to the truck for me if my hands are full......sometimes. If I need a refill I just swipe my card a second time at the pump when I'm filling the diesel truck, fill them both at once, set the filled plastic can in the bed of the truck and we are on our way.
I think I was thinking more along the lines of leveraging the 3 tanks already on the trailer and the BBQ quick connect. Also remember it is still TRI mode if you chose to use gas. I guess it all depends on how often you are using that generator and all the gas in the jerry can. - CampbellDaycruiExplorer
Your kidding right?
Nope. My plastic gas can sits flat and does not roll around the truck like propane tanks, does not scratch what I set it on and does not have to be unstrapped and lifted out of a fitted base in a compartment that's just a bit too tall and too narrow to manage comfortably. It also weighs so much less than a propane tank when empty that my wife is even willing to carry it out to the truck for me if my hands are full......sometimes. If I need a refill I just swipe my card a second time at the pump when I'm filling the diesel truck, fill them both at once, set the filled plastic can in the bed of the truck and we are on our way. - 352Explorer
Your kidding right? - dennis1949ExplorerWe had propane Honda generators and pumps at work. Always had to work on them till we converted them to gas. Then we had very little trouble with them
- CampbellDaycruiExplorerIMHO propane is the most trouble/hassle to fill of all the fuels we use: for some reason I have no problem with taking a 5 gallon plastic gasoline can to be filled, but I feel like doing the same with a propane tank is being a real PITA. Stopping at a gas pump and squirting a few gallons into a can without having to go inside and find an employee to fire up the propane dispenser seems a whole lot simpler.....
- 352ExplorerHERE
ol Bombero-JC wrote:
Not sure what "kit" you mean... US Carb, or?
(I prefer Maine Diesel - send 'em your carb, returned "converted" with regulator, and necessary parts).
Converted my Yam 2400is to tri-fuel - with no intent to ever run it again on gasoline.
Works great for me - nat gas at home, propane (in needed) "on the road".
No problems *ever* with contaminated or "old" gasoline, no need for Seafoam or StaBil.
BTW - you might take your question to the Tech Forum (or ask the mod to move it) - as *everything* generator is there.
~ - 352Explorer
SabreCanuck wrote:
Interesting topic, I didn't even know you could do the conversion but see huge benefits in doing so.. Propane for fuel in 5th wheel, why carry/store gasoline? (diesel truck).
Just commenting to follow :)
That is indeed why I posted this topic. - SabreCanuckExplorerInteresting topic, I didn't even know you could do the conversion but see huge benefits in doing so.. Propane for fuel in 5th wheel, why carry/store gasoline? (diesel truck).
Just commenting to follow :) - wilber1Explorer20 lbs of propane is about 4.7 gallons. Propane contains about 20 percent less energy by volume than gasoline.
- RbertalottoExplorerHow long does a set of Honda 2000 generators run on 20 pounds of propane?
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
