ependydad
Jan 08, 2020Explorer
With 3,000 pounds of cargo carrying capacity left, you're looking at fifth wheels in the range of 12,000 lbs (if 25% pin weight) to 15,000 pounds (if 20% pin weight).
The challenge then is looking at the weight carried by the rear axle and making sure there's enough leftover in the GAWR and the tire loading capacity.
If you can take the truck loaded up like you would normally travel, it'll tell you real numbers of what's left over from a payload and rear GAWR perspective.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
