John,
Not much to add... no problems with my Husky. I also
have the sliding version, not sure I need it , but have it
so may prove beneficial at some point. I would add, ...
make sure it gets installed correctly (and correct
location)... and occasional checks on bolt torque may
be wise. I do wish it had a little higher quality (or more
resilient) paint, but easily remedied with occas. touch-ups.
I use one of the silicone pads so face of hitch still in
good shape. I keep mine covered (bungy and RV tire cover),
but many favor bed covers to keep idle hands from messing
with hitch. When they say keep hands and fingers away from the
slide bar... not just a recommendation... easy to donate body
parts if you forget. Husky customer service was very helpful
when I asked questions after purchase. I did paint my slide bar
with Lime green fluorescent paint to make it easier to see when
properly engaged ( but still do the "pull test" with pads
slightly elevated). I would buy "new" as some of the "used" ones
I have seen do not instill confidence... might have been older
Valley versions , so not sure support exists.
Bottom line, no regrets. Good luck.
Charles
