arglebargle's avatar
arglebargle
Hydraulic slide out issues while traveling
After buying a used 5th wheel, prepping it, and setting out on our cross country journey, we thought we had all of our ducks in a row, but our hydraulic slide out mechanism stopped functioning at our 2nd stop. The bedroom slide would go out, but the other 2 would not - they just kind of shuddered for a moment while the pump made straining noises. After calling about 30 RV service centers (any shop that seemed somewhat reputable on google) within a few hundred miles, we found out that every single one of them had a long (2 - 6 weeks) wait in their service schedule - the shortest wait we could find would only be 10 days before they could look at our rig. After mulling over the risks and the alternatives, we decided to drive about a hundred miles and take it to this shop.
The guys at this shop were professional and super nice. After a few days, they tested and diagnosed our problem as a weak hydraulic pump (well, partially weak - apparently retraction was strong enough, but in reverse, the pump pressure was weak). It took a week and a few days to get the new pump shipped and installed, so we decided to extend our time in Colorado (luckily our schedule is pretty flexible) and cabin camp in some of the cool mountainous places we wanted to go, but were too afraid to tow our rig. When the shop called and told me that the pump was replaced, the slides were working, and the rig was ready to go, since we were about 500 miles away at this point, we decided to finish our current cabin reservations and pick it up in 2 days.
At this point, it seemed like we were trouble-free and were pretty excited to continue the rest of our journey. After getting to the shop and trying to hitch up, the first thing that I noticed was that the hydraulic landing gear no longer worked at all. The switch appeared to be completely dead, rendering the unit un-hitchable. I called a tech over and asked him about it and he was super nice and apologetic. He and a few others started testing the switch wiring and pretty quickly discovered that there was no voltage to the switch. After spending a few minutes on it, they were able to reconnect the switch and voila - the landing gear worked and we were hitched up. This seemed odd to me since we had never had problems with that switch before - not sure what was going on there, but I figure it must have been related to the pump replacement.
My skepticism finally won out over my laziness and compulsion to get on the road, so I decided that I'd better slow down and actually test the slides before leaving the shop. When I did, the symptoms were exactly as before - the bedroom slide went out (although kinda sluggishly - it's always been a bit sluggish), but the other slides did nothing more than a bit of a shudder as the pump strained when it got to be their turn. I talked to the tech again, who was again super apologetic and somewhat perplexed. He said that he had replaced the pump himself and that the last step of replacing it was to work the slides in and our several times to make sure there weren't air bubbles in the hydraulic line (I might be describing that wrong), so he had personally seen them go in and out at least 5 times immediately after the replacement.
After poking around on it for a while, it became clear that no amount of fiddling with the slide in/out switch was going to resolve the problem, so we left the trailer with them, modified our schedule again, and booked more cabin time. Unfortunately we won't be able to hear back from them until their weekend is over.
Now I love cabins, and I love this area of the country, but it's a pretty stressful and nerve-wracking experience not knowing what's going on here (I don't know much about hydraulic systems, unfortunately). Right now, my worst fear is that when I talk to the shop next week, they will tell me that they can't or won't fix the underlying issue and I'll be back to square one (well, except for the wasted weeks and money - boy was that unnecessary pump expensive), which is kind of a nightmare for me. I have a (perhaps unreasonable) fear that this problem is tricky to diagnose and if I don't familiarize myself with the troubleshooting procedures or likely culprits, they will try to shirk the job. This is a repeated pattern for me with other truck/auto shops I've been to and tricky to diagnose issues - if I don't crawl up their butt and ask every question about everything they did to diagnose an issue, they will shrug and hand it back, ignoring requests to fix/diagnose trickier problems and only addressing super straight-forward issues. In my experience only repeated rounds of "what were your results when you performed this specific test?" and "well, maybe you could try that and get back to me?", are able to get tricky auto issues diagnosed - I am scared it might be the same with RV service shops, too, but don't yet have enough experience to tell. It's possible I don't know how to talk to shops properly - I might be too nice/thankful, undercutting a sense a urgency or threat of an angry customer, but that's another discussion altogether, haha.
So does this description of the hydraulic issue jump out to anyone as symptoms of a specific problem (well, except battery related issues, we eliminated that at the shop by running off their external battery pack - no change in behavior). After reading the Lippert hydraulic service manual (found the PDF on google), I'm suspecting that it might be a leak in the hydraulic line. This kind of makes sense to me because the slides worked fine in Texas, but as soon as we got a little elevation in Colorado (~4000 ft from about sea level), they stopped working - I think it would have to be a pretty small leak, though, to only affect the pump-replaced system after a few days and for there not to be any leaking hydraulic fluid present, and for the landing gear and bedroom slide to still work. This is not my area of expertise, though, so my guess could be totally off.
If it is a hydraulic leak, is that the sort of repair a reputable shop might try to shirk to get me out of there? Ie, is it possible they might try to get rid of me by saying they don't do hydraulic leaks and if so, is that legitimate (and I should just move on) or sketchy (and I should call them out on it)? Is a leak in the hydraulic line a "hard" problem to fix? I could imagine so (I mean, how do you find it if it's small? Lippert's manual certainly doesn't address that), but I don't have enough experience to say for sure.
I'm also curious if anyone has any advice for other ways I could (or could have) addressed the problem. The only other option I considered was hiring a mobile mechanic, but I decided against since we were on the road and many of the parks I've seen have rules against repairing your rig during your stay. I was also concerned that since it's a hydraulic issue, hydraulic fluid could come gushing out during the repair and I could get charged by a campground for staining their gravel or something. I also had concerns that hydraulic issues might be too complex for a mobile tech with limited shop/tool access. But maybe there's another way or a good place I could meet a mobile mechanic? Any other options there that maybe I overlooked?
Thanks for reading my long post.
