rrbowman wrote:
rrbowman wrote:
I have a 2010 Montana with 4 slideouts that are all controlled with 1 switch. when connected to electric I have no issues, but when on battery power the last slide comes in probably 6 inches then stops, I let off the switch and then press again and it comes in another 6 inches. I keep this up until fully in. Naturally this is the LR slide that is the largest and heaviest. I think it is a battery capacity issue but just want to know if anyone has experienced this and what they found out.
Thank everyone for their help. Looks like the battery needs replaced.
I bought unit used so I didn't know what battery was in it. I will replace with a higher capacity battery
You need to replace the breaker with a 80 amp. Been there, done that.
Go to http://montanaadministrator.forumco.com/default.asp and you will find it is a common problem and the 80 amp breaker is the solution.
