Mr_Fixit
Apr 16, 2014Explorer
The nose side side seams are pristine and spotless of any signs of tension/compression that you would expect to possibly show ..
The screw breakage was in the past from what I understand, and after opening up the holes slightly (instead of size on size) as they connected the seam of the nose cone and the underskin panel, the problem stopped. I have to admit that while not on a 5th wheel, I have seen screws break simply because they are cheap grade ...
If there was cracks/bent/etc you would expect to see "something" telling I would expect ...
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 22, 2026
