Hi eyetatto,
Ah, but in the "real world" there is this nasty thang called "in rush current". I certainly would not use a 50 watt inverter--and in fact in your shoes I'd use a 300 watt. Why? Because the capacitors in the 300 watt will be lots larger--and therefor "surge" (another name for in rush) may be better taken care of.
I started with a 50, then got a 150, then a 300, then a 700, then 1000, and now I'm pretty happen with a 2500 watt inverter. None of the above were pure sine wave. The 150 and up ran my laptop computers just fine.
That said, pure sine wave in the 300 watt range is fairly inexpensive, and even a 600 watt psw can be had for very little money.
I am looking for a 3000 to 4000 watt psw unit.
Eyetattoo wrote:
So I'm trying to figure out how much "power" I actually need. I don't want to buy something that is way too big, seeing as that would be just a waste of money. Below is a link to my TV and from what I see it draws 25.8 watts. My sat box is a non-HD non-DVR Directv box and it looks like it should draw somewhere between 10-20 watts from what I found on the second link. So if these figures are correct do I really only need 50 watts of power for the two? Thanks!
Vizio TV
Directv Box
