ADV__Scott's avatar
ADV__Scott
Jacks for leveling
I have a WW 2100FK. The only leveler/stabilizer it came with are the two cantilevers mounted in the rear. I currently use those and add two pyramid jacks up front to stabilize it. I use Lynx-style blocks for mot of the leveling.
I have been looking at the scissor-style jacks and have a question. If I mount one on each corner of the trailer (yes, I will beef up the are where they are welded) can I use them to level the trailer instead of driving up on blocks? Of course I would still try to find a "flat" spot, but would like to be able to adjust the level and stabilize at the same time without the hassle of using Lynx-style blocks.
Thanks
  • No. Sorry.
    Those scissor-style jacks are not strong enough or sturdy enough for lifting. They will raise your camper a little, but not strong enough to actually lift it. Besides, those jacks are hand cranked. I've tried cranking mine several times to actually "lift" the camper, and I just can't get enough "umph" to turn the handle after it reaches a certain point.
    I have lowered the tongue jack, tightened the rear scissor jacks, and then raised the tongue jack to give an "extra" bit of tension to the back of the camper for more stability. But not enough to lift it.
    I have also been on campsites that were so uneven, front to back, my tongue jack was not long enough to raise the front end of the camper to make it level. In those situations, I'll extend the tongue jack as far as I can, then tighten down the scissor jacks, then crank up the tongue jack and the scissor jacks will be holding the camper up on the front. I can then put more lumber under the tongue jack making it higher, then lower the tongue jack again to continue raising the front. For those few moments, they held. But I wouldn't trust them to support the camper at all for more than 30 seconds!
    Answer to your question.... "no."
