oldmanriver809's avatar
Oct 08, 2019
Jayco Eagle replacement ac motor
Hi everyone I hope someone can help me out with my installation of the replacement Fasco ac motor I just purchased. My original motor had bad bearings and froze up. I purchased the exact motor only newer since the original is from 2008. The original has two brown wires that plug into the capacitor. I had to mark one with a marker before I removed it for replacement. My problem is that the replacement has two brown wires too but one is brown and white and the other is brown and black so I have no idea which one plugs into which capacitor.. I can’t figure out how to post the wiring diagram that is on the motors or else I would. Thank you all in advance.
  • Cougar28 yes the new motor is the same model numbers and parameters. Also the black, red, and white wires on each diagram indicate the same “com”, “high”, and “low”
  • OK just making sure. It doesn't matter which side of the capacitor which one of the brown wires goes to. Just be sure you get the red-black and white back correctly.
    Dose the new motor use the same size capacitor as the old? Not a bad idea to replace the old capacitor when you replace the motor.
    Just wire the brown/white as tho it's all brown. It is marked that way so it can be wired as a 3 wire setup . I am not going to confuse you on how to do that. I'm retired AC guy.
  • Cougar28 yes both motors actually have five total wires on each. The black, red, and white are on both motors which I will connect to each color accordingly but the brown wires are different.
