CdaddyExplorerAug 14, 2017Jayco outlet replacementOur outlet with USB ports pulled out of the wall in the bunkhouse. Can these just be replaced with a NY standard outlet I get at home improvement store?
DiskDoctrExplorerAug 15, 2017If you're replacing the electrical box, just watch your depth. Some of the walls aren't very thick ;)
Related ContentNo power on outside GFCI outletAdding power outlets in slide with no wiringElectrical outlet issuesReplacement Lights for TTOutlet problem
