I have 2014 Heartland Bighorn and it was very easy to install JTs at the rear stabilizers. Explore the fiber belly pan between the rear stabilizers and locate the frame cross member. Measure first for best location to install the stabilizer bracket, then cut a very small hole in the fiber belly pan to finish fit where you want the bracket to be attached. Drill pilots holes then drill holes to size and bolt to frame cross member. Mine works great and really does the finishing touch on stabilizing our rig. Send me a PM and I will give you my home number if you need more info. Good luck.
Lakeside
