Njmurvin wrote:
Found the sheared bolt. The square tube slips over the round shaft. I just have to get it lined up and replace the bolt. I had to do this same fix for my 1994 Terry. Couldn't they come up with a better design 17 years later?
I still think I have a problem with the motor straining too much to lift the nose. But, for now, it will be good to have both sides going up and down.
BTW, to get to level, the bottom of the trailer is right at 36" off the ground. Subtract 3.5" for the block and that means the jacks are extended 31.5". Is that too much?
That might be a lubrication issue. There were a couple of recent threads related to that. Find the one where we discussed lubricating the leadscrews.
