FLY_4_FUN
Dec 19, 2016Explorer
So is it your large slide on the drivers side? I am having a similar issue with my dinette slide, and it does sound like metal on metal. Looking underneath I wonder if its where the ram goes into the pass-through hole of the frame? There might be something to the rubber also as now that mine's a year old im sure the rubber is less pliable. I did use brake cleaner on all the exposed "workings" I could see and then used a light dry silicone spray on cogs/gears etc but no change. Im wondering if when the slide "tips" as it comes in if the floor is just dragging on an area that should have had a wear strip...
For sure let us know if you track it down, possibly with pics as there is no way im going to a dealer as they will say its normal. I don't think that a loud squeal inside and out is normal and may lead to wear on a part I cant fix easily or cheap.
Daryll
Daryll
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
