Jerry_B's avatar
Jerry_B
Leaky water connections
My Mobile Suites is plumbed with Pex tubing and fittings. Reinforced hose is used such as to hook up the water heater and the whole house filter. They used Pex fittings to join the hoses at these several locations. The hose is 1/2 inch where the Pex is less than that. So they used double clamps to hold the hose on the smaller Pex fittings. They leak! Anyone else experienced this and corrected it?
  • My fifth wheel has pex fittings thru-out and over the years of beating and banging up and down the road 1 or 2 are gonna leak. This past weekend the toilet in the bunkhouse had a small leak but had the floor all wet. I loosened the pex fitting all the way and then re-tightened and leak was gone. End of last season carpet wet in living area, I worked my way in and up thru the entertainment center..... All the way to the ceiling and there it was, loose pex fitting... Re- tightend and all good.
    I think it's good to check all the fittings every once in awhile,
    Problem is I've had two leak that were behind a wall, luckily both inside the entertainment center to easy to get to.
