Frank55
Jun 28, 2019Explorer
Leaky waterhose
I keep having a waterleak on the hose coming into the trailer. I have put a new washer, used teflon tape and have tightened it up as much as I can an it still leaks! Any suggestions.
SailingOn wrote:But doesn't that just transfer the drips/leaks to where the Banjo fitting is attached to the hose?
Banjo fittings, one on the trailer and one on the hose, make a solid leakproof connection, and don't corrode. I think they're lots easier to connect/disconnect than the standard hose ends. First picture is the hose end, second the trailer end.
