Old-Biscuit
Feb 26, 2017Explorer III
djgarcia wrote:
5th. wheel--- Reverse the springs on the trailer axles.
Exactly.......
Instead of 'band-aid fixes' get the 5th wheel level when towing
Nose high (enough that YOU are uncomfortable when using bed) is not a good situation.
Lighter pin weight, rear tires/axle/suspension stresses.
Do what is necessary to level the 5th wheel when towing
An axle flip....change leaf springs form under axles to on top of axles IF they are not already on top
If leaf springs are already on top of axles then do a subframe light
Goggle both to fully understand
But towing NOSE HIGH is not proper and needs to be corrected.
About Fifth Wheel Group
