laknox
Feb 27, 2017Nomad
GaryS1953 wrote:
We have a small 5th wheel that tows with the front too high for us to park and sleep in the camper without unhooking and leveling. In most cases that is fine, but if we want to overnight at a Walmart or other such place we are really in uncomfortable unhooking from the tow vehicle. I was thinking of some sort of small ramps that I could put under the wheels and pull up on them to raise the rear of the camper. Ideally I would always park on a slope, but usually don't have that option. Can anyone recommend some small inexpensive ramps that could raise the camper 8 inches, and will last more than a couple of uses?
8 INCHES!? You need to address the unlevel towing, big time. Not only does it produce extra stress on the suspension and tires, if you run with the fridge on, you risk of destroying the cooling system. Also, if you have < 6" clearance over the truck bed, you run the risk of hitting the rear bed corners.
Lyle
About Fifth Wheel Group
