batavia02
Apr 08, 2017Explorer
"Lite" 5th wheel models
Just wanted to put this out there what is the thought about lite models such as flagstaff,rock wood and others in term of quality and overall durability just to be curious
mileshuff wrote:I could be wrong but I though we were comparing apples to apples, not apples and oranges.wing_zealot wrote:A high end RV made for full timing is considerably heavier and often worth it. Thicker walls and better insulation, heated under carriage, more room in full profile bedrooms, heavier cabinetry so door latches, rails and screws don't come loose from lighter soft woods.
Aluminum frame construction is lighter then wood frame construction and just as durable. Laminated fiberglass is lighter then aluminum sided and just as durable.
Saying a lite 5'er can do just as well full time on the road as a heavier trailer and last just as well is not always correct. That said, a quality lite trailer can be well built and do just fine for most RV'ers.
