RobWNY wrote:
Second Chance wrote:
RobWNY wrote:
I have a new Salem Hemisphere GLX 286RL. It has a dry Pin Weight of 1625
"Dry" pin weights are useless. 23% of trailer's GVWR to estimate loaded pin weight on a fifth wheel.
Rob
I agree with you but I have no idea how to calculate what the loaded Pin weight would be on a 5th wheel when you have no idea what the OP is going to put in his camper and while it's parked at a dealer. At least the Dry Pin Weight gives the OP a starting point. It eliminates any 5th wheel that has a dry Pin Weight greater than what the OP needs. Care to share your thoughts on how an accurate Pin Weight is calculated without knowing what's going to be in the 5th Wheel and how to measure the exact weight of the Pin while the dealer is showing the units the OP is interested in? I can't say any dealer I've spoken with brought out a certified scale for me to get accurate readings before I made a decision.
As you say, the only way to truly know is to load up and head for the CAT scales. However, a rule of thumb used frequently on all of the forums on which I participate (including Escapees where there are a LOT of old-timers) is to use 23% of the fifth wheel's GVWR for an estimated loaded pin weight. Time after time this has proven to be within a few hundred pounds once propane, batteries, and average contents in the basement and front bedroom are loaded. Looking at trailers where the advertised "dry" pin weight is only a few hundred pounds under the truck's payload will likely result in a situation where the truck's rear axle and/or tires are over their rated capacities once the trailer is loaded. Best to know what the likely maximum pin weight will be to stay within the envelope. Bottom line is that, no matter how capable the Cummins diesel is, the OP still has a 1/2-ton truck.
That said, I would agree with the other poster who suggested looking at the Grand Design Reflection 150 series. There are a several folks over on the Grand Design forum towing the 150 series (and some of the smallest "regular" Reflections) with the F-150s with the Max Tow and Max Payload packages.
Rob
