NorthwestBound's avatar
Oct 25, 2015
Looking for our 1st 5ver, many questions....
New to the forums. So we got a good deal on a diesel 07 Ram 2500 and now we are tring to decide on the rest of the rig.
Im looking at a fleetwood savanna 35 5w. Triple slide gvwr 13600lb, truck weighs 7060 with fuel and 2 ppl. 4200 frt, 2860 rear.
Would this be a safe and legal rig?
  • NorthwestBound wrote:
    Is it the 20% that puts me over the 9000lb gvwr?
    Yes, if the loaded to camp FW, only weighed 10,000 lbs, you would be at your GVWR, since you only have 1,940 available payload left. You still have to take away 200 lbs more for the hitch, so 1,740 left for pin wt.
    Many people tow over their trucks GVWR. You will have to decide if you want to do this. Is it safe? If not more than a few hundred lbs over, probably. You do not want to go over your RAWR!
    Jerry
  • With the truck weight subtracted from the 9,000 GVWR, you will have just short of 2,000 lbs to add. The hitch will be about 200 lbs. You will go over the GVWR of the truck. You will be close on the RAWR, but won't know for sure without weighing.
    If you take 20% of the FW GVWR, it will give you an idea on pin wt. If you add 200 lbs for the hitch, you will be close to 3,000 lbs added to the rear axle wt.
    Your truck will likely work for this trailer, but getting a smaller/lighter trailer, should be considered.
    Jerry
