Seattle Lion wrote:
The reason is that trailer tires are designed to stay in one place for long time periods without damage. LT's aren't. ST sidewalls are stiffer (one reason they get so hot is because they are thicker than LT's) to resist the scrubbing caused by the trailer being dragged around turns.
I am not happy about the bad reputation of my Tow Max tires. We have a heavy fifth wheel (13,500 lbs loaded).
Could you please sight a source for your misinformation about ST tires. The aging of a tire is about the same for all tires that set rather than move. However if you start with a really cheap tire like a ST tire, then they are not going to do better than a higher quality tire. All the marketing stuff about ST tires is just plan that, marketing, without facts to back it up.
Regarding the sidewall, the stiffness of a ST generally falls between a P rated tire and a LT rated tire.
And yes you should be very worried about your Tow Max tires, as they have earned the reputation they have as Blow Max tires.
What some of you fail to realize that the trailer manufacturers pay next to nothing for these tires from the likes of Tredit and Tireco.
If ST tires were as good as you suggest, we would not be reading this thread or all the other ST tires failure threads and you would not note the bad reputation of Tow Max.
Remember Goodyear makes this statement about their Marathon ST tire.
"Specifically designed to make trailer towing easier, more stable and more economical"
This from the same company that makes the pricey G614 LRG trailer tire. They do not label their G614 as economical!
Given that most ST tires size for size are about the same price, with the exception of the Maxxis M8008ST, I think the bunch minus Maxxis can be lumped together as economical vs quality.
Chris
