pipeliner345
Nov 15, 2013Explorer
Old-Biscuit wrote:
Those wires shouldn't have anything to do with electric...they should be for gas
In the AC junction box..factory wiring is:
BLACK...120V AC from ON/OFF switch to electric element
WHITE...Neutral from electric element
In the DC junction box....factory wiring is:
RED...12V DC positive....from ON/OFF switch (goes to/thru 12V DC t-stats to module board)
BLUE...12V DC positive....from module board to light
GREEN....ground/12V DC negative
YELLOW.....ground from module board to junction box
Module Board has Brown that is 12V DC positive to gas valve (Black from gas valve to ground)
Coach wiring......???
old biscuit, check out this unit. it is the one I had. the DEL
the DE has no orange wire. here is the link. you will see that the DEL replaces the yellow on a DE with an orange.
http://www.ebay.com/itm/SUBURBAN-10-GALLON-GAS-ELECTRIC-SW10DEL-RV-WATER-HEATER-CAMPER-DSI-LP-110-120V/370862950683?_trksid=p2047675.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D2732187662419938644%26pid%3D100011%26prg%3D1005%26rk%3D1%26rkt%3D5%26sd%3D350842781466%26
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
