Baja_Man's avatar
Baja_Man
New to me 5er....hitch recs needed
Hello All--
Well, finally made a decision and bought a small 5er. It is 1998 Jayco 243RKS. One owner and kept in xlnt. cond. Should work well for my family of four (Me, DW, DS10, DS16).
Trailer Specs:
GVWR: 9400
UVW: 6935
Water: 466 (56 gallons)
NCC: 2465
I would assume a hitch weight of 1800#
The hitch that came with the 5er is a Lil Rocker 15K (RBW) and the pin box is a Leland 7910. The hitch inclded the rails, L brackets and all hardware. It was mounted on late 80's Dodge Ram diesel truck. My truck is a 1992 Ford F350 SRW, long bed.
I don't know much about hitches and need some advice.
Is this older hitch still good and safe? What are pros and cons to this hitch?
Anything special about the Leland 7910 pin box?
Do I need a new hitch and what would I be gaining over the Lil Rocker?
Thanks!
  • I had the same hitch for several years. It will keep you awake when coming to a stop and taking off with the constant "clunking" !
    My Dad put many thousands and years on his RBW. His sliding bar actually broke!
    Personally I would not put the time or energy into that hitch.
    If your truck is set up for the universal mounting rails I would go that route.
