FF286's avatar
FF286
New truck. Old camper
I have a 2005 outback and just bought a 2019 Chevy 2500. Once I hooked up to the camper I only have about 3” of clearance between the camper and 5er. I am using a b&w companion and can raise the hitch one more notch, and can lower the kingpin one hole.
What I’m worried about is if the camper will ride nose high on the new truck. The axle is already on top of the springs. Is there anything that can be done to safely raise the camper to make it ride level?
    If you're only a couple inches nose-high, I wouldn't worry too much about it. 5-6", yeah, you need to do something. Not sure if the late model GMs have blocks in the suspension; I believe Ford and Ram do. If so, they could be removed and you'd gain a couple inches.
    As others have said, more than a 2" lift on the FW, and you =really= need to add a sub-frame between the main frame and the axles. You run the risk of twisting the frame or bending the spring hangers if you add blocks. Using a cross-brace is also highly recommended.
    Lyle
  • That little bit of adjustment should not really make the trailer too much nose high. I’d adjust and have at it. I adjusted our 2 holes and couldn’t see it was anymore high but the ruler measured just in front and back of wheels was only 1/2”.
  • if you raise the camper somehow with subframe or flipping the axles, consider the other issues. Frame Cross or X menbers may be needed to stiffen to deal with the added lateral loads. Thats best placed at the rear spring mounts.
    Landing and stabilizing gear may need blocks or spacers. How about the steps?
    Consult a frame and welding shop.
  • Set it up so you have good clearance between bed and bottom of trailer. Measure from back of trailer frame to the ground an then do it at the front of the frame. See how much you are high. I have a 36 ft and mine is about 10 inches higher in front than back, I have about 7 in bed clearance. Mine tows good and doesn’t seem to be a issue. Others may disagree, but works for me..
  • Yep I just mistyped that. Springs are on top of the axle.
  • cougar28 wrote:
    Move the axle's under the springs. (Springs on top of axle)
    Yes, this^^^^unless OP just wrote wrong, saying the axle already on top, and meant springs on top???
    Having a subframe built is another option, if needed.
    Jerry
