kzspree320
May 30, 2015Explorer
Some of the stuff listed above plus deodorizer for black water tank, OFF or other bug spray, a tool set since things do break while camping at times, WD40 or other lube for fifth wheel hitch, always have duck tape for emergency repairs, ice cube trays unless you have an ice maker, a flashlight since you may need to check on things at night, all your normal bedding, all your normal kitchen stuff, we tend to use paper plates to minimize dishwashing, highly recommend a surge protector at some point sooner than later, a voltmeter that you plug into socket and shows voltage.
Probably forgot some other stuff but others will add. The most important thing is to enjoy. Good luck. Keith
About Fifth Wheel Group
19,041 PostsLatest Activity: Apr 16, 2026
