fly-boy
Mar 24, 2014Explorer
Macs Dad wrote:
The original WW 28 footer had 2 axles and had issue's. WW added a third after they discovered (or should I say someone other that WW discovered) the weight issue with the two axles. Ya so from that wndering if the new 28 footer axles are rated correectly.
I still don't get the whole weight thing with toy hauler manufactures. Add the generator and its weight to the standard options list. Most will want it.
What are the cabinets made of ? That same pressboard used before is heavy. Use plywood or even a hollow core and save some weight. Why are they using a porcelan toilet (more weight). Whats wrong with with the plastic ones they weigh less.
It not like it can't be done. Mine came loaded and I had them weigh it when it came in and it was 7200 dry from a CAT scale and it's GVWR id 10,100 lbs and have had no issues with the weight. I do pull out without water and fill up close to my destination. It not a big deal for us.
The fresh water tank to the grey and black tank ratio is still wrong. 160 gallons of fresh water ?? Really ? And still a small grey tank. Make that dang grey tank bigger so I can stop dumping my grey in the desert please, LOL. 100 gallons of water should be more than enough. 30 gallon black and 70 gallon grey tanks please.
What side is the fuel station on. Hopefull the drivers side.
I would like see newer WW's on the road.
No way would I consider a trailer with only 100 gallons of water for dry camping- with two women in the trailer and 4 total we want all the water we can get!
I have no problem watering the plants with a little grey water- No water for showers and the toilet and we are headed home in a hurry. :)
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
