BeardedUtahn wrote:
I am about to cry. I just drilled one hole through the side of our brand new 2021 Grand Design fifth wheel while trying to install a tv wall mount. What is the easiest and best way to repair the hole? Is the trailer a total loss. Please go easy on me.
Before you drive yourself crazy, ...take a deep breath... EVERYTHING is fixable....( ALMOST )
1- does it go ALL THE WAY from inside to outside?
2- what size hole?
IF the outside hole is where you need it, squeeze sealant into the hole, place the mount on the exterior wall, dab some sealant onto the screw and tighten... that SHOULD take care of the exterior hole..
And for the inside...depending on where it is -
* seal it... AND
*hang a picture....
or
*place a piece of trim over it
or
*get a piece of wallpaper that matches, cut out a small diameter piece just large enough to cover the hole..
0r
*hang a coat hanger
