lawnspecialties's avatar
Dec 09, 2015
Pin Weights
How does one get an accurate pin weight of a 5er they are contemplating purchasing?
Do dealer's generally have a scale at their business? The Sherline on etrailer is rated only 2000 lbs. and is generally expected to measure trailer tongues.
I know if I want to buy a particular model, the pin weight at the dealership will be slightly different from real world towing with all our stuff inside. But I would never trust the manufacturer's specs and I certainly can't haul the thing to a local truck scale.
  • Would love to see =any= mfr send out a complimentary CAT scale weigh-in with the stipulation that you have to return the results back to them. They could then compile real-world numbers. I know the mfrs will never do this, but if a 3rd-party would do it, I'd bet they'd be inundated with info.
    Lyle
  • Super_Dave wrote:
    Many of the 5ers that I look at have that massive pass through storage up front. That has got to be a huge variable as forward loaded storage has to have a lot bigger impact on pin weight than axle back weight.
    True but the fridge can be over or behind the axles and there is either a fresh water or waste tank behind the axle.
    Didn't say it was perfect but it does help "estimate".
  • spud1957 wrote:
    I like using the dry weight ratio. Once loaded, the weight ratio would be similar.
    If the posted dry weight of the trailer is 10k with a dry pin weight of 2K. That unit has a 20% ratio. Load it up to 12k and you will be close to 2400 lbs.
    Some units' ratios are lower. Some are higher. Floor plan has a lot to do with it.
    On all the 5th wheels we've owned since 1996, loading the front storage bay results in the trailer being heavier on the pin than the dry pin/axle weight ratios would indicate. In other words, a 20% "dry" ratio might turn into a 23% or 24% "loaded" ratio.
    Rusty
  • Many of the 5ers that I look at have that massive pass through storage up front. That has got to be a huge variable as forward loaded storage has to have a lot bigger impact on pin weight than axle back weight.
  • I like using the dry weight ratio. Once loaded, the weight ratio would be similar.
  • rhagfo's avatar
    rhagfo
    Explorer III
    downtheroad wrote:
    Rough, fairly safe estimate....use 20% of the trailer's GVWR.
    (.20 x GVWR (gross trailer's weight rating).
    This is an great starting point the can be up to 25% though. Be aware if you are looking at a 14,000# 5er, the the difference between 20% and 25% is 700# which is a bit of variance.
  • The 20% rule can give a ballpark number. But it can also be off a lot. Browsing 5er manufacturer web sites and looking at specs, you will find some of the longer and heavier 5ers sometimes have lower pin weights than some of the shorter lighter ones. Sometimes significantly so. All about floor plans and layouts. Short of weighing it or getting weight info from someone who has that particular model, the manufacturer spec'ed pin weight is the best starting place.
  • Rough, fairly safe estimate....use 20% of the trailer's GVWR.
