avvidclif1 wrote:
I want it in inches. It tells me how much I need to raise the low side of the trailer. Degrees won't tell me if I need 1" or 2" boards without some calculations.
Ice boxes can run off level way more now then in the 1980's. After you use your 5th wheel enough and set up. You can look at the degree level and know how high to raise one side by the degrees it is off. It is just like anything else. It is experience. Just like after a few times of setting up. You get a system down. And it does not take as long to set up as the first time.
