RoyB
Jan 08, 2017Explorer III
Shouldn't be any draw unless commanded. I suspect the small LED you see come ON is just a small led across the two fuse contacts. It comes ON to tell you that the fuse has blown or pulled out like in your case. When a good fuse is plugged in around the LED contacts the LED light goes off... My 12VDC fuse positions in my 12VDC Power Distribution Panel all have the little LEDs for each ATM fuse position...
12VDC Power Distribution Fuse Panel
Google Image
Roy Ken
Google Image
Roy Ken
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
