EtempletonExplorerJan 08, 2017Power slide parasite power drawIs there a reason for a power Slide to have a parasite power draw? To clarify if the motor is not activated to move slide in or out should it bad consuming power? When I pull the fuse for it the led...Show More
fj12ryderExplorer IIIJan 08, 2017Our Fuzion is like RoyB described: if you pull a fuse the LED comes on.
Related ContentAdding power outlets in slide with no wiringParasitic Power Loss!Newbie power question12 Volt Power IssueBattery Isolator - Parasitic Current
