NC Hauler wrote:
jims1 wrote:
Once you hit the Continental Coach weight range, a true MDT will be needed. The CC coaches are in the 25K+ range. Friends of our have a CC that weighs 27k with empty tanks. For most DRV's and lower brands, you can go with a $70k pickup if you want.
We went with a fully loaded 610 Volvo for $19k already converted with 443000 miles on it.
So you've now moved the weight from 23K,(OP) and went to 25-27K plus..guess you'll get to where you need to justify a semi tractor rig....We were at 23K...It only takes common sense and simple math to figure at what 5er GVW that one would need a semi to tow it...You hit it..though your example is not that of the original post..re-read..
Well, got admit I paid about 63K for my fully loaded 2016 3500...full warranty and extremely comfortable and I can pull it into my carport, take it to drive thru ATM, Micky Dee drive thru, park at grocery store in regular parking places and use it as my daily driver to and from work..I can tow with it and park in church parking lot on Sunday..I can use the bed to haul a load of wood or whatever. use it all the time for any and everything...don't need a semi tractor no matter the price WAAY to big and not very practical in every day life to most...If they're so popular, one would think you would observe piles of them towing 5er's on the highway...I haven't seen it...A select few towing heavy 5er's that can now be towed by a 350/3500 and will argue till they're blue in the face that they're right, everyone else is wrong..Main reason I rarely frequent the escapees forum..extremely rude people ganging up on those that believe the way I do in today's world..The times, they are a changing.
You sprout that mess on every forum you can....
The OP asked about what is available to pull the heavier 5'ths. The Ford and Dodge can to an extent. But you don't know what the pin weights are on the custom RV's. Most CC's if over 40ft, will have 6000lb or more pin. Many go above 7500lbs. You can put that on a dually if you want, but it's not going to last long.
Also, read the fine print, most tow ratings are based on a gooseneck flatbed trailer like they show in all the commercials.
You were invited to the recent East Coast HDT rally. You elected not to attend. So before you trash talk us anymore, maybe you should learn a little more about this option. It may not be for you, but it may be for others.
