rivalrider
Apr 15, 2016Explorer
My previous trailer was an '05 FS2300. With a RZR, a quad, two dirt bikes and full water and fuel I weighed it at 8800lbs. I don't have tongue weight or the scale sheet for that one, towed with my '08 Tundra no problem. Horrible gas milage, but plenty of power.
I now have an '06 FB3000, the front bath model which gives me 20ft to the first cabinet. My sand car is 17ft long so I need the room. The original owner had the entire frame strengthened as well as the tongue extended/strengthened to be able to fit an 80 gallon gas tank(picture a truck bed tank) up there. He had some sort of baja race car hence the need for that much gas...
Anyways, the trailer is 37.5 feet long which is a large tow behind, but it is strong and stable.
I tow with an '08 Duramax CC/LB with EFI live tow tunes and exhaust brake. I also have air bags, and a Curt XD hitch. Here is my weigh sheet with sand rail, water, truck bed filled with about 40gal diesel in my external tank and full firewood. I did not un-hook so no exact tongue weight. I know the weight police will yell at me but this set up tows very stable and the truck pulls and stops it with no problems.
In my opinion any normal WW without the modifications mine has will work just fine with your truck as it will be lighter overall. I do enjoy the triple axel for stability and I run two stabilizers on hitch also. I'm guessing my trailer is just shy of 15k with about 2300lbs of tongue weight.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
