pcm1959
Nov 15, 2015Explorer II
pcm1959 wrote:
Just spoke to Eric at Quadra. He told me they are fully aware of the issue and are working on a new sensor. I didn't push him as to when it would be ready. In the meantime, he advised me to add the on/off switch that would cut the power to the sensor during travel. This would involve splicing into the red wire that come from the six pin wiring harness. I guess will try that simple $5 fix in the meantime while waiting for a new sensor from Quadra to correct the issue.
Oh, and btw buc1980, I'll pass on the Lippert system. LOL
I added the switch that was suggested and have not had any issues since. It completely cuts the power to the system. When I turn on the new switch, the read out says please wait then goes blank. Then I turn on the panel power switch. Once the system is leveled, I do the reverse - panel power off then the new switch to off.
Since the install of this switch, they system has worked fine for 3 full cycles.
About Fifth Wheel Group
