fulltime5er wrote:
Truck is a 2013 F350 dually, 3.73 ratio rear end, 4x4 6.7 diesel.
Trailers range between 15-20,000 gvwr, and 2250-2750 hitch weight.
Well you DEFINITELY have the truck for it, but I'm not sure of the GVWR and GCWR of the truck, though most use the trucks RAWR around here.. I believe the pin weights are a bit light though. If you actually had a 20,000# 5er, I would think the hitch weight could be closer to 4,000#...The pin weights you show look like "empty" or "dry" weights. Again, I believe a more realistic pin weight would be in the upper 3,000# range at the least...My 5er, last time weighed was 15,800# with a pin weight of 3300#....and GVWR on my 5er is 16,950#.
Still don't see an issue, Even if you go with a 43', it'll just take some getting use to when pulling into spots and backing up, but you'll get use to it.
You'll be limited at some campgrounds with a 43', more State Parks than anything else.
anyway....figure on a heavier pinweight than what you showed
